SANtricity commands
Show volume action progress - SANtricity CLI
Contributors netapp-driley
The show volume actionProgress command returns information about the volume action and amount of the long-running operation that is completed for a long-running operation on a volume.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Context
Note
With firmware version 7.77, the show volume actionProgress command is deprecated. Replace this command with show storageArray longRunningOperations.
The amount of the long-running operation that is completed is shown as a percentage (for example, 25 means that 25 percent of the long-running operation is completed).
Syntax
show volume [volumeName] actionProgress
Parameter
Parameter Description
volume
The name of a volume for which you want to retrieve information about a long running operation. Enclose the volume name in square brackets ([ ]). If the volume name has special characters or numbers, you must enclose the name in double quotation marks (" ") inside square brackets.
Minimum firmware level
5.43
