SANtricity commands
Show volume copy target candidates - SANtricity CLI
Contributors netapp-driley
The show volumeCopy source targetCandidates command returns information about the candidate volumes that you can use as the target for a volume copy operation. This command is valid for snapshot volume copy pairs.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
show volumeCopy source ["sourceName"] targetCandidates
Parameter
Parameter Description
source
The name of the source volume for which you are trying to find a candidate target volume. Enclose the volume name in square brackets ([ ]). If the volume name has special characters or numbers, you must enclose the volume name in double quotation marks (" ") inside square brackets.
