SANtricity commands
Show volume copy source candidates - SANtricity CLI
Contributors netapp-driley
The show volumeCopy sourceCandidates command returns information about the candidate volumes that you can use as the source for a volume copy operation. This command is valid for snapshot volume copy pairs.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
None.
Notes
This command returns volume copy source information as shown in this example.
Volume Name: finance
   Capacity: 4.0 GB
   Volume Group: 1
Volume Name: engineering
   Capacity: 4.0 GB
   Volume Group: 2
