Start disk pool locate - SANtricity CLI
The start diskPool locate command identifies the drives that are logically grouped together to form the specified disk pool by blinking the indicator lights on the drives.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
(Use the stop diskPool locate command to turn off the indicator lights on the drives.)
Syntax
start diskPool [diskPoolName] locate
Parameter
| Parameter | Description |
The name of the disk pool for which you want to locate. Enclose the disk pool name in square brackets ([ ]). If the disk pool name has special characters or numbers, you must enclose the disk pool name in double quotation marks (" ") inside square brackets. |
Minimum firmware level
7.83
