Start storage array controller health image - SANtricity CLI
The start storageArray controllerHealthImage controller command produces a storage array controller health image on storage arrays that support the controller health image feature.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
With firmware version 8.20 the |
Use this command only under the direction of technical support. |
If the storage array does not support the controller health image feature, the command returns an error.
Syntax
start storageArray controllerHealthImage controller [(a|b)]
| Parameter | Description |
This parameter specifies the controller from which to produce the controller health image. Valid controller identifiers are |
Notes
This command forces the selected controller to dump its core data to cache. Use the save storageArray controllerHealthImage command to save a copy of the cache data to a host file.
Minimum firmware level
7.83
8.20 replaces the coreDump parameter with the controllerHealthImage parameter.
