SANtricity commands
Start OCSP server URL test - SANtricity CLI
Contributors netapp-driley
The start storageArray ocspResponderUrl test command checks for an open connection to the specified URL of the Online Certificate Status Protocol (OCSP) server.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Parameter Description
url
The literal string of the OCSP server's URL.
Note
If you do not specify a URL, the command uses the OCSP responder URL found in the certificate revocation settings.
Syntax
start storageArray ocspResponderUrl test (url=stringLiteral)
Minimum firmware level
8.42
