Start storage array syslog test - SANtricity CLI
The start storageArray syslog test command allows you to test communications between the storage array and a syslog server.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
start storageArray syslog test id="<id>"
| Parameter | Description |
id |
Syslog configuration ID to test. The ID is available using the |
Example
SMcli -n Array1 -c "start storageArray syslog test id=\"331998fe-3154-4489-b773-b0bb60c6b48e\";" SMcli completed successfully.
Minimum firmware level
8.42
