SANtricity commands
Start volume group defragment - SANtricity CLI
Contributors netapp-driley
The start volumeGroup defragment command starts a defragment operation on the specified volume group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
Defragmenting a volume group starts a long-running operation that you cannot stop.
Syntax
start volumeGroup [volumeGroupName] defragment
Parameter
Parameter Description
volumeGroup
The name of the volume group that you want to defragment. Enclose the volume group name in square brackets ([ ]).
Notes
Host I/O errors might result in the volume groups with more than 32 volumes. This operation also might result in internal controller reboots because the timeout period ends before the volume group definition is set. If you experience this issue, quiesce the host I/O operations, and try the command again.
Minimum firmware level
6.10
