Start volume group locate - SANtricity CLI
The start volumeGroup locate command identifies the drives that are logically grouped together to form the specified volume group by blinking the indicator lights on the drives.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Use the stop volumeGroup locate command to turn off the indicator lights on the drives.
Syntax
start volumeGroup [volumeGroupName] locate
Parameter
| Parameter | Description |
The name of the volume group for which you want to locate the drives that belong to that volume group. Enclose the volume group name in square brackets ([ ]). |
Minimum firmware level
6.16
