SANtricity commands
Stop check volume parity job - SANtricity CLI
Contributors netapp-driley
The stop check volume parity job command stops an in-progress check volume parity job.
Supported Arrays
This command applies to any individual storage array, including the EF600, EF300, EF50, and EF80 arrays; as long as all SMcli packages are installed.
Roles
To execute this command on an EF600, EF300, EF50, and EF80 storage array, you must have the Storage Admin role.
Syntax
stop check volume parity job jobId=<job_id>;
Parameter Description
jobId
The job id corresponding to the check volume parity job to stop. This value is required.
Minimum firmware level
11.80
