SANtricity commands
Stop storage array iSCSI session - SANtricity CLI
Contributors netapp-driley
The stop storageArray iscsiSession command forces the termination of a storage array iSCSI session.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
stop storageArray iscsiSession [SessionNumber]
Parameter
Parameter Description
iscsiSession
The identifier number of the iSCSI session. Enclose the identifier number of the iSCSI session in square brackets ([ ]).
Minimum firmware level
7.10
