Suspend SSD cache - SANtricity CLI
The suspend ssdCache command temporarily stops caching for all of the volumes that are using the SSD cache.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Support Admin role.
Context
While caching is stopped, host reads are serviced from the base volumes instead of from the SSD cache.
Syntax
suspend ssdCache [ssdCacheName]
Parameter
| Parameter | Description |
The name of the SSD cache that you want to suspend. Enclose the SSD cache name in square brackets ([ ]). If the SSD cache name has special characters or numbers, you must enclose the SSD cache name in double quotation marks (" ") inside square brackets. |
Notes
To restart caching, use the resume ssdCache command.
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
