Validate storage array security key - SANtricity CLI
The validate storageArray securityKey command validates the security key for a storage array that has security-capable drives to make sure that the back-up security key file is not corrupt.
Supported Arrays
If external key management is enabled, then this command applies only to the E4000, E2800 and E5700 arrays. If internal key management is enabled, then the command applies to any individual storage array, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Security key validation uses the pass phrase used to generate the file to decrypt the key and match it with the value maintained in controller memory (for internal keys) or on the external server (for external keys).
This command applies to both internal and external key management. |
Syntax
validate storageArray securityKey file="fileName" passPhrase="passPhraseString"
| Parameter | Description | ||
The file path and the file name that has the security key. Enclose file path and the file name in double quotation marks (" "). For example: file="C:\Program Files\CLI\sup\drivesecurity.slk"
A character string that encrypts the security key so that you can store the security key in an external file. Enclose the pass phrase in double quotation marks (" "). |
Minimum firmware level
7.70
