Turn on locator lights in a pool, volume group, or SSD Cache
PDF of this doc site
Creating your file...
Your file is ready
You can locate drives to physically identify all of the drives that comprise a selected pool, volume group, or SSD Cache. An LED indicator lights up on each drive in the selected pool, volume group, or SSD Cache.
Steps
Select Storage › Pools & Volume Groups.
Select the pool, volume group, or SSD Cache you want to locate, and then click More › Turn on locator lights.
A dialog box appears that indicates the lights on the drives comprising the selected pool, volume group, or SSD Cache are turned on.
After you successfully locate the drives, click Turn Off.
