Why am I seeing a capacity over-allocation error when I have enough free capacity in a volume group to create volumes?
PDF of this doc site
Creating your file...
The selected volume group might have one or more free capacity areas. A free capacity area is the free capacity that can result from deleting a volume or from not using all available free capacity during volume creation.
When you create a volume in a volume group that has one or more free capacity areas, the volume's capacity is limited to the largest free capacity area in that volume group. For example, if a volume group has a total of 15 GiB free capacity, and the largest free capacity area is 10 GiB, the largest volume you can create is 10 GiB.
If a volume group has free capacity areas, the volume group graph contains a link indicating the number of existing free capacity areas. Select the link to display a pop-over that indicates the capacity of each area.
By consolidating free capacity, you can create additional volumes from the maximum amount of free capacity in a volume group. You can consolidate the existing free capacity on a selected volume group using one of the following methods:
When at least one free capacity area is detected for a volume group, the Consolidate free capacity recommendation appears on the Home page in the Notification area. Click the Consolidate free capacity link to launch the dialog box.
You can also select Pools & Volume Groups › Uncommon Tasks › Consolidate volume group free capacity to launch the dialog box.
If you want to use a specific free capacity area rather than the largest free capacity area, use the Command Line Interface (CLI).
