SANtricity software
Configure storage array group
You create storage groups, and then add storage arrays to the groups.
Configuring groups is a two-step procedure.
Step 1: Create group
You first create a group. The storage group defines which drives provide the storage that makes up the volume.
Steps
  1. From the Manage page, select Manage Groups › Create storage array group.
  2. In the Name field, type a name for the new group.
  3. Select the storage arrays that you want to add to the new group.
  4. Click Create.
Step 2: Add storage array to group
You can add one or more storage arrays to a user-created group.
Steps
  1. From the main view, select Manage, and then select the group that you want to add storage arrays to.
  2. Select Manage Groups › Add storage arrays to group.
  3. Select the storage arrays that you want to add to the group.
  4. Click Add.
