Drive states
SANtricity System Manager reports various states for drives.
Accessibility states
| State | Definition |
Bypassed |
The drive is physically present, but the controller cannot communicate with it on either port. |
Incompatible |
One of the following conditions exists:
Removed |
The drive has been improperly removed from the storage array. |
Present |
The controller can communicate with the drive on both ports. |
Unresponsive |
The drive is not responding to commands. |
Role states
Assigned |
The drive is a member of a pool or volume group. |
In-use hot spare |
The drive is currently being used as a replacement for a drive that has failed. Hot spares are used only in volume groups, not pools. |
Standby hot spare |
The drive is ready to be used as a replacement for a drive that has failed. Hot spares are used only in volume groups, not pools. |
Unassigned |
The drive is not a member of a pool or volume group. |
Availability states
Failed |
The drive is not working. The data on the drive is not available. |
Impending Failure |
It has been detected that the drive could fail soon. The data on the drive is still available. |
Offline |
The drive is not available for storing data usually because it is part of a volume group that is being exported or it is undergoing a firmware upgrade. |
Optimal |
The drive is working normally. |
