SANtricity software
What do I need to know before creating a mirror consistency group?
Follow these guidelines before you create a mirror consistency group.
Note
Synchronous mirroring is not available on the EF600 or EF300 storage system.
You create a consistency group in Unified Manager in the Create Mirrored Pairs wizard.
Meet the following requirements for Unified Manager:
  • The Web Services Proxy service must be running.
  • Unified Manager must be running on your local host through an HTTPS connection.
  • Unified Manager must be showing valid SSL certificates for the storage array. You can accept a self-signed certificate or install your own security certificate using Unified Manager and navigating to Certificate › Certificate Management.
Also be sure to meet the following requirements for storage arrays:
  • The two storage arrays must be discovered in Unified Manager.
  • Each storage array must have two controllers.
  • Each controller in both the primary array and secondary array must have an Ethernet management port configured and must be connected to your network.
  • The storage arrays have a minimum firmware version of 7.84. (They can each run different OS versions.)
  • You must know the password for the local and remote storage arrays.
  • Your local and remote storage arrays are connected through a Fibre Channel fabric or iSCSI interface.
