SANtricity software
What else do I need to do to configure or diagnose iSER over InfiniBand?
Contributors Vaishnavi-Totewar
The following table lists the SANtricity System Manager functions that you can use to configure and manage iSER over InfiniBand sessions.
Note
The iSER over InfiniBand settings are available only if your storage array's controller includes an iSER over InfiniBand host management port.
Action Location
Configure iSER over InfiniBand ports
  1. Select Hardware.
  2. Select the Controllers & Components tab.
  3. Select a controller.
  4. Select Configure iSER over InfiniBand ports.
or
  1. Select Settings › System.
  2. Scroll down to iSER over InfiniBand settings, and then select Configure iSER over InfiniBand Ports.
View iSER over InfiniBand statistics
  2. Scroll down to iSER over InfiniBand settings, and then select View iSER over InfiniBand Statistics.
