SANtricity software
Show front and back views in SANtricity System Manager
The Hardware page can show either the front view or the back view of the shelves.
About this task
The back view shows the controllers/IOMs and the power-fan canisters. The front view shows the drives.
Steps
  1. Select Hardware.
  2. If the graphic shows the drives, click the Controllers & Components tab.
    The graphic changes to show the controllers instead of the drives.
  3. If the graphic shows the controllers, click the Drives tab.
    The graphic changes to show the drives instead of the controllers.
  4. Optionally, you can select Show all front or Show all back, located at the bottom of the page.
