SANtricity software
Change the reserved capacity settings for a mirrored pair volume in SANtricity System Manager
You can change the settings for a mirrored pair volume to adjust the percentage point at which SANtricity System Manager sends an alert notification when the reserved capacity for a mirrored pair volume is nearing full.
Steps
  1. Select Storage › Pools & Volume Groups.
  2. Select the Reserved Capacity tab.
  3. Select the mirrored pair volume that you want to edit, and then click View/Edit Settings.
    The Mirrored Pair Volume Reserved Capacity Settings dialog box appears.
  4. Change the reserved capacity settings for the mirrored pair volume as appropriate.
    Field details
    Setting Description
    Alert me when…​
    Use the spinner box to adjust the percentage point at which System Manager sends an alert notification when the reserved capacity for a mirrored pair is nearing full.
    When the reserved capacity for the mirrored pair exceeds the specified threshold, System Manager sends an alert, allowing you time to increase reserved capacity.
    Note Changing the Alert setting for one mirrored pair changes the Alert setting for all mirrored pairs that belong to the same mirror consistency group.
  5. Click Save to apply your changes.
