SANtricity software
Edit key management server settings in SANtricity System Manager
If you configured external key management, you can view and edit the key management server settings at any time.
Steps
  1. Select Settings › System.
  2. Under Security key management, select View/Edit Key Management Server Settings.
  3. Edit information in the following fields:
    • Key management server address — Enter the fully qualified domain name or the IP address (IPv4 or IPv6) of the server used for key management.
    • Key management port number — Enter the port number used for the Key Management Interoperability Protocol (KMIP) communications.
      Optional: you can include another key server by clicking Add Key Server.
  4. Click Save.
