SANtricity software
Edit syslog servers for alerts in SANtricity System Manager
You can edit the server address used for receiving syslog alerts.
Steps
  1. Select Settings › Alerts.
  2. Select the Syslog tab.
  3. From the table, select a syslog server address, and then click the Edit (pencil) icon from on the far right.
    The row becomes an editable field.
  4. Edit the server address and UDP port number, and then click the Save (checkmark) icon.
Results
The updated server address appears in the table.
