SANtricity software
Import certificates for controllers when acting as clients in SANtricity System Manager
If the controller rejects a connection because it cannot validate the chain of trust for a network server, you can import a certificate from the Trusted tab that allows the controller (acting as a client) to accept communications from that server.
Before you begin
  • You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
  • The certificate files are installed on your local system.
About this task
Importing certificates from the Trusted tab might be necessary if you want to allow another server to contact the controllers (for example, an LDAP server or a syslog server that uses TLS).
Steps
  1. Select Settings › Certificates.
  2. From the Trusted tab, select Import.
    A dialog box opens for importing the trusted certificate files.
  3. Click Browse to select the certificate files for the controllers.
    The file names display in the dialog box.
  4. Click Import.
Results
The files are uploaded and validated.
