SANtricity software
View imported certificate information in SANtricity System Manager
From the Certificates page, you can view the certificate type, issuing authority, and the valid date range of certificates for the storage array.
Before you begin
You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
Steps
  1. Select Settings › Certificates.
  2. Select one of the tabs to view information about the certificates.
    Tab Description
    Array Management
    View information about the CA-signed certificates imported for each controller, including the root file, intermediate file(s), and the server file(s).
    Trusted
    View information about all other types of certificates imported for the controllers. Use the filter field under Show certificates that are…​ to view either user-installed or pre-installed certificates.
    • User-installed — Certificates that a user uploaded to the storage array, which can include trusted certificates when the controller acts as a client (instead of a server), LDAPS certificates, and Identity Federation certificates.
    • Pre-installed — Self-signed certificates included with the storage array.
    Key Management
    View information about the CA-signed certificates imported for an external key management server.
