SANtricity software
View controller settings in SANtricity System Manager
Contributors netapp-driley netapp-jolieg
You can view information about a controller, such as the status of the host interfaces, drive interfaces, and management ports.
Steps
  1. From the left panel, select menu:Hardware[Controllers and components].
  2. Do one of the following actions to display the controller settings:
    • Click the controller to display the context menu, and then select View settings.
    • Select the controller icon (next to the Shelf drop-down list). For duplex configurations, select either Controller A or Controller B from the dialog box, and then click Next.
      The Controller settings sliding menu opens.
  3. Review the sections to move between controller property settings.
    Field details
    Section Description
    Details
    Shows the controller status, date/time, model name, and replacement part number.
    Current configuration
    Shows the current firmware version and NVRAM version.
    Data cache
    Shows data cache totals.
    Data cache modules
    Shows cache module location, status, and capacity.
    Processor cache
    Shows processor cache totals.
    Cache backup devices
    Shows cache backup device location, status, and capacity.
    Host interfaces
    Shows host interface information and link status for each port.
    Drive interfaces
    Shows drive interface information and link status for each port.
    Management port settings
    Shows management port details, including controller hostname, remote login, and IP network settings.
    Domain name system (DNS) server settings
    Shows DNS configuration, primary DNS server, and backup DNS server.
    Network time protocol (NTP) server settings
    Shows NTP service and NTP server configuration details.
  4. Click Close.
