SANtricity software
Suspend or resume mirrored pair synchronization in SANtricity System Manager
Contributors netapp-driley netapp-jolieg
You can use the Suspend option and Resume option to control when to synchronize the data on the primary volume and the secondary volume in a mirrored pair.
About this task
If a mirrored pair is manually suspended, the mirrored pair will not synchronize until it is manually resumed.
Steps
  1. From the left panel, select Mirroring › Synchronous mirroring.
  2. Select the mirrored pair that you want to suspend or resume, and then select either More › Suspend or More › Resume.
    The system displays a confirmation.
  3. Select Yes to confirm.
Results
System Manager performs the following actions:
  • Either suspends or resumes data transfer between the mirrored pair without removing the mirror relationship.
  • For a suspended mirrored pair:
    • Displays Suspended in the Mirrored Pair table.
    • Logs any data that was written to the primary volume of the mirrored pair while synchronization is suspended.
  • For a resumed mirrored pair, writes the data automatically to the secondary volume of the mirrored pair when synchronization is resumed. A full synchronization is not required.
