SANtricity software
View unsynchronized data amount between mirror consistency groups in SANtricity System Manager
Contributors netapp-driley netapp-jolieg
You can view the amount of unsynchronized data between the mirror consistency groups on the local storage array and on the remote storage array. While the mirror consistency group is in an Unsynchronized status, no mirroring activity takes place.
About this task
You can perform this task when the selected mirror consistency group contains mirrored pairs and when synchronization is not currently in-progress.
Steps
  1. From the left panel, select Mirroring › Asynchronous mirror consistency groups.
  2. Select the Mirror Consistency Groups tab.
    The Mirror Consistency Group table appears and displays all the mirror consistency groups associated with the storage array.
  3. Click More › View unsynchronized data amount.
    If unsynchronized data exists, the table values reflect this. The data amount column lists the unsynchronized data amount in MiB.
