Configure iSCSI ports in SANtricity System Manager
If your controller includes an iSCSI host connection, you can configure the iSCSI port settings from the System page.
Your controller must include iSCSI ports; otherwise, the iSCSI settings are not available.
You must know the network speed (the data transfer rate between the ports and the host).
The iSCSI settings and functions only appear if your storage array supports iSCSI. |
From the left panel, select System.
Under iSCSI Settings, select Configure iSCSI Ports.
The Configure iSCSI Ports option appears only if System Manager detects iSCSI ports on the controller.
Select the controller with the iSCSI ports you want to configure.
In the drop-down list, select the port you want to configure, and then click Next.
Select the configuration port settings, and then click Next.
To see all port settings, click the Show more port settings link on the right of the dialog box.
Field Details
Port Setting Description Configured ethernet port speed (Appears only for certain types of Host Interface Cards)
Select the speed that matches the speed capability of the SFP on the port.
Forward Error Correction (FEC) mode (Appears only for certain types of Host Interface Cards)
If desired, select one of the FEC modes for the specified host port.
The Reed Solomon mode does not support the 25 Gbps port speed. Enable IPv4 / Enable IPv6
Select one or both options to enable support for IPv4 and IPv6 networks.
If you want to disable port access, deselect both check boxes. TCP listening port (Available by clicking Show more port settings.)
If necessary, enter a new port number.
The listening port is the TCP port number that the controller uses to listen for iSCSI logins from host iSCSI initiators. The default listening port is 3260. You must enter 3260 or a value between 49152 and 65535.
MTU size (Available by clicking Show more port settings.)
If necessary, enter a new size in bytes for the Maximum Transmission Unit (MTU).
The default Maximum Transmission Unit (MTU) size is 1500 bytes per frame. You must enter a value between 1500 and 9000.
Enable ICMP PING responses
Select this option to enable the Internet Control Message Protocol (ICMP). The operating systems of networked computers use this protocol to send messages. These ICMP messages determine whether a host is reachable and how long it takes to get packets to and from that host.
If you selected Enable IPv4, a dialog box opens for selecting IPv4 settings after you click Next. If you selected Enable IPv6, a dialog box opens for selecting IPv6 settings after you click Next. If you selected both options, the dialog box for IPv4 settings opens first, and then after you click Next, the dialog box for IPv6 settings opens.
Configure the IPv4 and/or IPv6 settings, either automatically or manually. To see all port settings, click the Show more settings link on the right of the dialog box.
Field Details
Port setting Description Automatically obtain configuration
Select this option to obtain the configuration automatically.
Manually specify static configuration
Select this option, and then enter a static address in the fields. (If desired, you can cut and paste addresses into the fields.) For IPv4, include the network subnet mask and gateway. For IPv6, include the routable IP address and router IP address.
Enable VLAN support (Available by clicking Show more settings.)
Select this option to enable a VLAN and enter its ID. A VLAN is a logical network that behaves like it is physically separate from other physical and virtual local area networks (LANs) supported by the same switches, the same routers, or both.
Enable ethernet priority (Available by clicking Show more settings.)
Select this option to enable the parameter that determines the priority of accessing the network. Use the slider to select a priority between 1 (lowest) and 7 (highest).
In a shared local area network (LAN) environment, such as Ethernet, many stations might contend for access to the network. Access is on a first-come, first-served basis. Two stations might try to access the network at the same time, which causes both stations to back off and wait before trying again. This process is minimized for switched Ethernet, where only one station is connected to a switch port.
Click Finish.
