SANtricity software
Enable a premium feature in SANtricity System Manager
Contributors netapp-driley netapp-jolieg
A premium feature is an extra option that requires a key to enable.
Before you begin
  • You have obtained a feature key. If necessary, contact technical support for a key.
  • You have loaded the key file on the management client (the system with a browser for accessing System Manager).
About this task
This task describes how to use System Manager to enable a premium feature.
Note
If you want to disable a premium feature, you must use the Disable Storage Array Feature command (disable storageArray) (featurePack | feature=featureAttributeList) in the Command Line Interface (CLI).
Steps
  1. From the left panel, select System.
  2. Under Add-ons, select Enable premium feature.
    The Enable a premium feature dialog box opens.
  3. Click Browse, and then select the key file.
    The file name is displayed in the dialog box.
  4. Click Enable.
