E-Series storage systems
Cabling your storage system - E-Series
Contributors netapp-driley netapp-asubhas NetAppZacharyWambold netapp-lisa netapp-ivanad netapp-echurch netapp-jolieg netapp-jsnyder
You can cable a host directly to a controller or use switches to connect a host to a controller.
If your storage system includes one or more drive shelves, you must cable them to your controller shelf. You can add a new drive shelf while power is still applied to other components of the storage system. In addition, you can connect your storage system to a network for out-of-band management.
The cabling information is intended for a hardware installer or system administrator who is installing or expanding a storage system. It is assumed that you have installed the storage system as described in the Installation and Setup Instructions for your hardware.
Applicable hardware model
Cabling information applies to the following hardware models.
Note If you do not see your controller shelf (storage system) listed below, see Quick start for E-Series and click the link for your specific storage system to access the cabling information.
Controller Shelf Drive Shelf
EF300, EF600, EF300C, EF600C
DE212C, DE224C, DE460
E5724, EF570, E4012, E2812, E2824, EF280
DE212C, DE224C
E4060, E2860, E5760
DE460C
Additional cabling information
If you are cabling for any of the following configurations, see Adding IOM Drive Shelves to an Existing E27XX, E56XX, or EF560 Controller Shelf.
E2712, E2724, E5612, E5624, EF560
DE212C, DE224C
E2760, E5660
DE460C
For information about cabling to support mirroring features, see the Synchronous and Asynchronous Mirroring Feature Descriptions and Deployment Guide.
