Learn about I/O module maintenance for EF50 and EF80 storage systems
The EF50 and EF80 storage systems offer flexibility in replacing or upgrading I/O modules to enhance network connectivity and performance, and increase storage capacity.
When an I/O module in your storage system fails, you can replace it with the same type of I/O module to restore the storage system to its optimal operating state.
You can upgrade I/O modules in your storage system to increase the number of host ports for enhanced network connectivity, expand your system’s ability to handle data traffic, and connect SAS expansion shelves.
SAS expansion I/O modules are supported on storage systems running SANtricity 12.10 or later.
