Requirements to replace the power supply in an EF300 or EF600 storage system
Before replacing a power supply in an EF300, EF600, EF300C, or EF600C array, review the following requirements.
You must have a replacement power supply that is supported for your controller shelf or drive shelf model.
Do not mix PSUs of different voltage types. Always replace like for like. |
You must have an ESD wristband, or you have taken other antistatic precautions.
