Rack-mount hardware - E-Series
Rack-mount hardware is used to install your storage system in a rack or cabinet. Installation instructions should be included in the rack-mount hardware box. However, if you need to access installation instructions, use the applicable link below.
For newer storage systems, you can verify the supported rack-mount hardware by seeing the NetApp Hardware Universe at NetApp Hardware Universe.
Adjustable support rails
Access Installing adjustable support rails for installing a controller-drive tray or a drive tray that was shipped separately (not already installed in the cabinet). This procedure is applicable for the following 2U (9 cm or 3.5 inch) trays:
DE1600 or DE5600
E2612 or E2624
E5412, E5424, E5512, or E5524
