Remove remote storage object for SANtricity Remote Storage Volumes
After an import completes, you can remove a remote storage object if you no longer want data copied between the local and remote devices.
Steps
Make sure that no imports are associated with the remote storage object you plan to remove.
From the Remote Storage screen of the SANtricity System Manager, select the desired Remote Storage object under the result list section.
Click Remove.
The Confirm Remove Remote Storage Connection dialog is displayed.
Confirm the operation by typing
removeand then clicking Remove.The selected Remote Storage object is removed.
