Manage SNMP
You can configure Simple Network Management Protocol (SNMP) in your cluster.
You can select an SNMP requestor, select which version of SNMP to use, identify the SNMP User-based Security Model (USM) user, and configure traps to monitor the SolidFire cluster. You can also view and access management information base files.
You can use both IPv4 and IPv6 addresses. |
