Volume pairing warnings
PDF of this doc site
Manage storage with Element software
- Protect your data
Creating your file...
TheVolume Pairs page on the Data Protection tab provides these messages after you pair volumes. These messages can display on both source and target ends of the pair (unless otherwise indicated) in the Replicating Volumes list view.
PausedClusterFull
Because the target cluster is full, source replication and bulk data transfer cannot proceed. The message displays on the source end of the pair only.
PausedExceededMaxSnapshotCount
The target volume already has the maximum number of snapshots and cannot replicate additional snapshots.
PausedManual
Local volume has been manually paused. It must be unpaused before replication resumes.
PausedManualRemote
Remote volume is in manual paused mode. Manual intervention required to unpause the remote volume before replication resumes.
PausedMisconfigured
Waiting for an active source and target. Manual intervention required to resume replication.
PausedQoS
Target QoS could not sustain incoming IO. Replication auto-resumes. The message displays on the source end of the pair only.
PausedSlowLink
Slow link detected and stopped replication. Replication auto-resumes. The message displays on the source end of the pair only.
PausedVolumeSizeMismatch
Target volume is not the same size as the source volume.
PausedXCopy
A SCSI XCOPY command is being issued to a source volume. The command must complete before replication can resume. The message displays on the source end of the pair only.
StoppedMisconfigured
A permanent configuration error has been detected. The remote volume has been purged or unpaired. No corrective action is possible; a new pairing must be established.
