Make the destination volume writeable
PDF of this doc site
Manage storage with Element software
- Protect your data
Creating your file...
When disaster disables the primary site for a SnapMirror DR relationship, you can serve data from the destination volume with minimal disruption. You can reactivate the source volume when service is restored at the primary site.
You need to make the destination volume writeable before you can serve data from the volume to clients. You can use the snapmirror quiesce
command to stop scheduled transfers to the destination, the snapmirror abort
command to stop ongoing transfers, and the snapmirror break
command to make the destination writeable.
You must specify the Element source path in the form <hostip:>/lun/<name>
, where “lun” is the actual string “lun” and name
is the name of the Element volume.
Stop scheduled transfers to the destination:
snapmirror quiesce -source-path <hostip:>/lun/<name> -destination-path <SVM:volume>|<cluster://SVM/volume>
For complete command syntax, see the man page.
The following example stops scheduled transfers between the source volume
0005
at IP address 10.0.0.11 and the destination volumevolA_dst
onsvm_backup
:cluster_dst::> snapmirror quiesce -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst
Stop ongoing transfers to the destination:
snapmirror abort -source-path <hostip:>/lun/<name> -destination-path <SVM:volume>|<cluster://SVM/volume>
The following example stops ongoing transfers between the source volume
0005
onsvm_backup
:cluster_dst::> snapmirror abort -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst
Break the SnapMirror DR relationship:
snapmirror break -source-path <hostip:>/lun/<name> -destination-path <SVM:volume>|<cluster://SVM/volume>
The following example breaks the relationship between the source volume
0005
onsvm_backup
onsvm_backup
:cluster_dst::> snapmirror break -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst
