Element Software
Edit a virtual network
Contributors netapp-pcarriga
You can change VLAN attributes, such as VLAN name, netmask, and size of the IP address blocks. The VLAN tag and SVIP cannot be modified for a VLAN. The gateway attribute is not a valid parameter for non-VRF VLANs.
If any iSCSI, remote replication, or other network sessions exist, the modification might fail.
When managing the size of VLAN IP address ranges, you should note the following limitations:
  • You can only remove IP addresses from the initial IP address range assigned at the time the VLAN was created.
  • You can remove an IP address block that was added after the initial IP address range, but you cannot resize an IP block by removing IP addresses.
  • When you try to remove IP addresses, from either the initial IP address range or in an IP block, that are in use by nodes in the cluster, the operation might fail.
  • You cannot reassign specific in-use IP addresses to other nodes in the cluster.
You can add an IP address block by using the following procedure:
  1. Select Cluster > Network.
  2. Select the Actions icon for the VLAN you want to edit.
  3. Select Edit.
  4. In the Edit VLAN dialog box, enter the new attributes for the VLAN.
  5. Select Add a Block to add a non-continuous block of IP addresses for the virtual network.
  6. Select Save Changes.
Link to troubleshooting KB articles
Link to the Knowledge Base articles for help with troubleshooting issues with managing your VLAN IP address ranges.
Looking for answers?
Try Doc, our Gen AI Assistant.
