Element Software
Volume performance details
Contributors netapp-pcarriga
You can view performance statistics of volumes from the Volume Performance page of the Reporting tab in the Element UI.
The following list describes the details that are available to you:
  • ID
    The system-generated ID for the volume.
  • Name
    The name given to the volume when it was created.
  • Account
    The name of the account assigned to the volume.
  • Access Groups
    The name of the volume access group or groups to which the volume belongs.
  • Volume Utilization
    A percentage value that describes how much the client is using the volume.
    Possible values:
    • 0 = Client is not using the volume
    • 100 = Client is using the max
    • >100 = Client is using the burst
  • Total IOPS
    The total number of IOPS (read and write) currently being executed against the volume.
  • Read IOPS
    The total number of read IOPS currently being executed against the volume.
  • Write IOPS
    The total number of write IOPS currently being executed against the volume.
  • Total Throughput
    The total amount of throughput (read and write) currently being executed against the volume.
  • Read Throughput
    The total amount of read throughput currently being executed against the volume.
  • Write Throughput
    The total amount of write throughput currently being executed against the volume.
  • Total Latency
    The average time, in microseconds, to complete read and write operations to a volume.
  • Read Latency
    The average time, in microseconds, to complete read operations to the volume in the last 500 milliseconds.
  • Write Latency
    The average time, in microseconds, to complete write operations to a volume in the last 500 milliseconds.
  • Queue Depth
    The number of outstanding read and write operations to the volume.
  • Average IO Size
    Average size in bytes of recent I/O to the volume in the last 500 milliseconds.
