Element Software
Volume pairing messages
Contributors netapp-pcarriga
You can view volume pairing messages during the initial pairing process from the Volume Pairs page under the Data Protection tab. These messages can display on both source and target ends of the pair in the Replicating Volumes list view.
  • PausedDisconnected
    Source replication or sync RPCs timed out. Connection to the remote cluster has been lost. Check network connections to the cluster.
  • ResumingConnected
    The remote replication sync is now active. Beginning the sync process and waiting for data.
  • ResumingRRSync
    A single helix copy of the volume metadata is being made to the paired cluster.
  • ResumingLocalSync
    A double helix copy of the volume metadata is being made to the paired cluster.
  • ResumingDataTransfer
    Data transfer has resumed.
  • Active
    Volumes are paired and data is being sent from the source to the target volume and the data is in sync.
  • Idle
    No replication activity is occurring.
