Element Software
SSL ciphers
SSL ciphers are encryption algorithms used by hosts to establish a secure communication. There are standard ciphers that Element software supports and non-standard ones when FIPS 140-2 mode is enabled.
The following lists provide the standard Secure Socket Layer (SSL) ciphers supported by Element software and the SSL ciphers supported when FIPS 140-2 mode is enabled:
  • FIPS 140-2 disabled
    TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 (dh 2048) - A
    TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 (dh 2048) - A
    TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 (dh 2048) - A
    TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 (dh 2048) - A
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (secp256r1) - A
    TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (secp256r1) - A
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (secp256r1) - A
    TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (secp256r1) - A
    TLS_RSA_WITH_3DES_EDE_CBC_SHA (rsa 2048) - C
    TLS_RSA_WITH_AES_128_CBC_SHA (rsa 2048) - A
    TLS_RSA_WITH_AES_128_CBC_SHA256 (rsa 2048) - A
    TLS_RSA_WITH_AES_128_GCM_SHA256 (rsa 2048) - A
    TLS_RSA_WITH_AES_256_CBC_SHA (rsa 2048) - A
    TLS_RSA_WITH_AES_256_CBC_SHA256 (rsa 2048) - A
    TLS_RSA_WITH_AES_256_GCM_SHA384 (rsa 2048) - A
    TLS_RSA_WITH_CAMELLIA_128_CBC_SHA (rsa 2048) - A
    TLS_RSA_WITH_CAMELLIA_256_CBC_SHA (rsa 2048) - A
    TLS_RSA_WITH_IDEA_CBC_SHA (rsa 2048) - A
    TLS_RSA_WITH_RC4_128_MD5 (rsa 2048) - C
    TLS_RSA_WITH_RC4_128_SHA (rsa 2048) - C
    TLS_RSA_WITH_SEED_CBC_SHA (rsa 2048) - A
  • FIPS 140-2 enabled
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (sect571r1) - A
    TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (sect571r1) - A
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (sect571r1) - A
    TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (sect571r1) - A
