Delete saved criteria
You can delete the saved search criteria.
About this task
You must have the name of the saved criteria in order to delete the saved criteria.
Steps
  1. Click the delete icon X under the Action column. The pop up is displayed asking you whether or not you want to delete the saved criteria.
  2. Click Yes to delete saved criteria.
  3. Click No to retain saved criteria.
