Edit saved criteria
You can edit the saved search criteria that you saved earlier. You can add any new components to the saved criteria or remove the component from existing saved criteria.
Before you begin
You must load the saved criteria for editing it.
Steps
  1. Load the saved criteria, click the saved criteria link.
  2. Click the Refine Search Criteria link. You can add or remove the criteria from saved criteria.
