Saving a recent search
From the Welcome to the IMT page, you can save your recent searches to preserve the criteria for later searches.
Steps
  1. Click Solution Search or Advanced Search.
  2. Select search criteria.
  3. Select Skip to Results or click Next to refine your search criteria and then navigate to the View Supported Configurations (results) page.
A popup dialog informs you that your criteria is automatically saved.
