Select a component to upgrade or downgrade
You can use What If feature in the Results page, to upgrade or downgrade a component in your product configuration. You can change the components and explore the compatibility.
Steps
  1. Click What If to view the components you can upgrade or downgrade to modify the selected configuration.
  2. Click a category to view the available components for upgrade or downgrade.
  3. In the available options window, you can search for a specific component version and select it.
  4. If the selected component is a valid configuration and compatible with your earlier configuration, then the compatibility message is displayed. You can now export the results to view all the supported configurations.
