Subscribe to Categories
You can subscribe to single or multiple categories of your choice.
About this task
You will receive an email notification when components are added or deleted from a category.
Steps
Click the Subscription link from the header menu.
In the subscription window, select the Category tab.
For the category of your choice, select the checkbox for the Components added or deleted option.
In the Frequency field, select Immediate or Digest.
The default selection is Immediate. -
Click Subscribe to get subscriptions for the categories that you have subscribed.
You can click Reset to clear all of the selections in the Category tab. |
