Keystone
3.0
Installation requirements for Keystone ITOM Collector
Contributors netapp-shwetav
Before installing ITOM Collector, ensure that your systems are prepared with the necessary software and meet all required prerequisites.
Prerequisites for the ITOM Collector server VM:
  • Supported operating system:
    • Debian 12 or later
    • Windows Server 2016 or later
    • Ubuntu 20.04 LTS or later
    • Red Hat Enterprise Linux (RHEL) 8.x
    • Red Hat Enterprise Linux 9.0 or later
    • Amazon Linux 2023 or later
      Note The recommended operating systems are Debian 12, Windows Server 2016, or newer versions.
  • Resource requirement: The VM resource requirements based on the number of NetApp nodes monitored are as follows:
    • 2-10 nodes: 4 CPUs, 8 GB RAM, 40 GB Disk
    • 12-20 nodes: 8 CPUs, 16 GB RAM, 40 GB Disk
  • Configuration requirement: Ensure that a read-only account and SNMP are configured on the monitored devices. The ITOM Collector server VM also needs to be configured as an SNMP trap host and Syslog server on the NetApp cluster and cluster switches, if applicable.
Networking requirements
The networking requirements of ITOM Collector are listed in the following table.
Source
Destination
Protocol
Ports
ITOM Collector
NetApp ONTAP cluster management IPs
HTTPS, SNMP
TCP 443, UDP 161
Monitoring of the ONTAP controllers
NetApp ONTAP cluster and node management IPs
ITOM Collector
SNMP, Syslog
UDP 162, UDP 514
SNMP traps and Syslogs from controllers
ITOM Collector
Cluster switches
SNMP
UDP 161
Monitoring of switches
Cluster switches
ITOM Collector
SNMP, Syslog
UDP 162, UDP 514
SNMP traps and Syslogs from switches
ITOM Collector
StorageGRID nodes IPs
HTTPS, SNMP
TCP 443, UDP 161
SNMP monitoring of StorageGRID
ITOM Collector
SNMP, Syslog
UDP 162, UDP 514
SNMP traps from StorageGRID
ITOM Collector
Keystone Collector
SSH, HTTPS, SNMP
TCP 22, TCP 443, UDP 161
Keystone Collector monitoring and remote management
ITOM Collector
Local DNS
DNS
UDP 53
Public or private DNS services
ITOM Collector
NTP server(s) of choice
NTP
UDP 123
Time keeping
