Keystone
3.0
Search Keystone data, generate reports, and view alerts
Contributors netapp-shwetav
You can search and filter your data, generate reports for subscriptions and usage, and view alerts to stay informed about your storage environment.
Search and filter data from NetApp Console
In the Console, you can search and filter Keystone data based on the column parameters available in the table within a tab. For example, in the Subscriptions tab under the Subscriptions page, you can filter data by entering the Keystone version in the search box. Similarly, in the Volumes in clusters tab under the Assets page, you can filter volumes by entering volume name in the search box.
You can refine your searches by using the advanced filter option where available. For example, in the Subscriptions tab, you can filter data by Keystone version, billing period, highest capacity, and days to subscription expiry, and in the Volumes in clusters tab, you can filter by volume name, cluster name, volume type, and more. Multiple filters can be applied simultaneously to narrow down your results with precision.
advance filter option
Generate reports from NetApp Console or Digital Advisor
You can generate and view reports for your Keystone data using the download button report download icon 2 in the Console available in tabs within the Console or Digital Advisor. These tabs allow you to generate reports for your subscriptions, historical usage, burst usage, performance, assets, volumes and objects.
The details are generated in CSV format that you can save for future use and comparison.
Generate health reports from NetApp Console
Use the NetApp Console to generate or schedule health reports for one or more subscriptions. These PowerPoint reports consolidate subscription usage, operational health, risks, and vulnerabilities. Digital Advisor does not support health assessment report generation or scheduling.
Generate consolidated report from Digital Advisor
In Digital Advisor, you can generate and view a consolidated report for your subscriptions, historical usage, burst usage, performance, assets, and volumes and objects. To do this, select Keystone Subscriptions as the report type from the Report feature in Digital Advisor. You can generate these reports at the customer, cluster, watchlist, or subscription level.
Create report
The report is generated in Excel format, with each type of information, such as subscription details or usage history, displayed on separate sheets. These sheets are named according to the tabs on the Keystone Subscriptions page for easy viewing. You can save the report for future use.
To learn more about generating reports, refer to Generate custom reports.
