Kubeflow Deployment
This section describes the tasks that you must complete to deploy Kubeflow in your Kubernetes cluster.
Prerequisites
Before you perform the deployment exercise that is outlined in this section, we assume that you have already performed the following tasks:
You already have a working Kubernetes cluster, and you are running a version of Kubernetes that is supported by the Kubeflow version that you intend to deploy. For a list of supported Kubernetes versions, refer to the dependencies for your Kubeflow version in the official Kubeflow documentation.
You have already installed and configured NetApp Trident in your Kubernetes cluster. For more details on Trident, refer to the Trident documentation.
Set Default Kubernetes StorageClass
Before you deploy Kubeflow, we recommend designating a default StorageClass within your Kubernetes cluster. The Kubeflow deployment process may attempt to provision new persistent volumes using the default StorageClass. If no StorageClass is designated as the default StorageClass, then the deployment may fail. To designate a default StorageClass within your cluster, perform the following task from the deployment jump host. If you have already designated a default StorageClass within your cluster, then you can skip this step.
Designate one of your existing StorageClasses as the default StorageClass. The example commands that follow show the designation of a StorageClass named
ontap-ai-flexvols-retainas the default StorageClass.
The ontap-nas-flexgroup Trident Backend type has a minimum PVC size that is fairly large. By default, Kubeflow attempts to provision PVCs that are only a few GBs in size. Therefore, you should not designate a StorageClass that utilizes the ontap-nas-flexgroup Backend type as the default StorageClass for the purposes of Kubeflow deployment.
$ kubectl get sc
NAME PROVISIONER AGE
ontap-ai-flexgroups-retain csi.trident.netapp.io 25h
ontap-ai-flexgroups-retain-iface1 csi.trident.netapp.io 25h
ontap-ai-flexgroups-retain-iface2 csi.trident.netapp.io 25h
ontap-ai-flexvols-retain csi.trident.netapp.io 3s
$ kubectl patch storageclass ontap-ai-flexvols-retain -p '{"metadata": {"annotations":{"storageclass.kubernetes.io/is-default-class":"true"}}}'
storageclass.storage.k8s.io/ontap-ai-flexvols-retain patched
$ kubectl get sc
ontap-ai-flexvols-retain (default) csi.trident.netapp.io 54s
Kubeflow Deployment Options
There are many different options for deploying Kubeflow. Refer to the official Kubeflow documentation for a list of deployment options, and choose the option that is the best fit for your needs.
For validation purposes, we deployed Kubeflow 1.7 using deployKF 0.1.1. |
